87-93 Mustang/99-04 Cervinis Stalker Fog Lights
Old 11-30-2010, 01:47 AM
schmallz
schmallz's Avatar
Default 87-93 Mustang/99-04 Cervinis Stalker Fog Lights
It's my understanding that they are infact the same fog light. One of mine has burned out. I removed the light to try to open it but it looks like it's sealed tight from the factory, is it possible to open these fog lights and replace the bulb?
schmallz is offline
Old 11-30-2010, 02:02 AM
schmallz
schmallz's Avatar
Those smoked for lights from LMR look so niccccccce.
They're cheaper than the stock 99-04 fog lights, even better.
schmallz is offline
Old 11-30-2010, 10:08 AM
ALMOST STOCK
ALMOST STOCK's Avatar
87-93 fog lights and blub replacement should all the same.
ALMOST STOCK is offline
Old 11-30-2010, 10:38 AM
schmallz
schmallz's Avatar
Thanks, you da man.
Do you know what type of bulb?
schmallz is offline
Old 11-30-2010, 11:36 AM
ALMOST STOCK
You'll need a H3-55W
Old 11-30-2010, 11:46 AM
ALMOST STOCK
If you removed the fog lamp assembly you may want to re-aim your fog lights.
Aiming Fog Lights
Where the fog light bolts onto the car, there is a bracket that holds the fog light in place, if you loosen that nut from the back, the fog light can pivot up and down and a little bit left and right. Once you get it pointed where you want it, tighten it down
Old 11-30-2010, 01:29 PM
schmallz
schmallz's Avatar
I'm just thinking about getting a pure white bulb or something, the lenses are clear but the actual light was always a yellow hue. Doesn't look right with my Raxiom Angel Eyes.
schmallz is offline
Old 11-30-2010, 07:51 PM
ALMOST STOCK
Let us know how that works out for you along with part number if you would.
Old 07-21-2013, 04:44 AM
Andreas Pfeil
Andreas Pfeil's Avatar
fog lights from '87-'93 are the same like the fog lights for the '99-'04 Cervinis Stalker Body Kit?
did i understand it right?? (i´m from germany and my english is not the best^^)
greethings form bavaria
Andreas Pfeil is offline
Old 07-21-2013, 09:46 AM
ALMOST STOCK
The Cervini's Stalker fog lights for the 99-04 are 5" round the 87-93 Stock GT fog lights are 4-1/2" round.
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: 87-93 Mustang/99-04 Cervinis Stalker Fog Lights
