Fuel System Questions
Hey all, I have been having some fuel pressure issues, and I recently replaced my fuel filter to no avail, hoping to have a cheap fix. I eventually want to have AN lines on the car for reliability's sake, and I have a Walbro 255lph fuel pump sitting at home ready to be installed. But I figured while I was doing that it may be a good time to swap out the fuel lines as well.
I eventually want to supercharge this car to over 700hp (Obviously, just waiting on the money thing), and I keep seeing threads about sumps. Should I be skipping out on the Walbro pump and going right to a sump?? Anyone have any helpful suggestions for me?
Thanks in advance.
Thanks in advance.
yes, you should sump the tank. A car making ~500hp can run the baffle are dry in the tank during a hard take off... which makes for all kinda of cool problems with running lean.
My new engine will be getting a sumped tank
Ok well that makes good sense. Will I still be able to use the Walbro pump that I purchased? Also, do lowered vehicles see any problems with the sumped tank, being that the sump itsself will present a lower than typical area on the tank?
Do you recommend purchasing a sumped fuel cell, or just welding in a sump onto the stock tank?
Does anyone have a particular fuel cell or weld-in sump to use?
Thanks again
Thanks again
