Can you tighten the doors?
Old 02-02-2011, 11:33 AM
BlackBetty93GT
BlackBetty93GT's Avatar
Default Can you tighten the doors?
I was wondering if there is a way to make the doors close tighter. My passanger door when shut you can see light out of the top right when sitting in the car. Therefor when it rains, all the water comes in the door right there and soaks my carpet., my dirver door isnt as bad but it leaks a little too from the same spot
BlackBetty93GT is offline
Old 02-02-2011, 11:49 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if it's just in the corner , sounds like the framing that goes/guides the window to the top may be tweaked a tad, I have grabbed a hold of the framing with widow down of course and braced myself and bent the frames back in a tad, it doesn't take much to achieve the result
mjr46 is offline
Old 02-02-2011, 12:52 PM
frdmstng1986GT
frdmstng1986GT's Avatar
+1. I have had to do that After locking the keys in my car and using the air bag to pump open the door a little. Usually you can just bend it back no problem.
frdmstng1986GT is offline
Old 02-03-2011, 07:42 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Also check to be sure you have the plastic bushing on the striker. That will usually cause the whole door to be out a little but it may have something to do with it.
Boss_Hotrod is offline
Old 02-04-2011, 06:48 PM
Quickbird144
Quickbird144's Avatar
+1
Was just about to say this.
Quickbird144 is offline
Old 02-04-2011, 08:31 PM
Jfsram
Jfsram's Avatar
Maybe it just needs new weatherstripping.
Jfsram is offline
Old 02-05-2011, 03:46 AM
rtintwo
rtintwo's Avatar
If everything is in good shape as far as bushings and hinges and the door isnt bent. Pull the weatherstriping down and bend the flange out some to press the weatherstip tighter to the door.
rtintwo is offline
jerrytubes
10-23-2015 12:11 PM
Sixer4Life
10-12-2015 04:26 AM
Sixer4Life
09-29-2015 07:03 PM
09-25-2015 06:58 PM
Quick Reply: Can you tighten the doors?
