car starts but dies right after
Old 04-07-2012, 11:38 PM
kevbaker1987
kevbaker1987's Avatar
Default car starts but dies right after
I took off my upper intake manifold off to change the valve cover gaskets and when i put everything back together the car started right up but it dies right after it finishes starting up
Any help is well appreciated i need it to be fixed asap
kevbaker1987 is offline
Old 04-08-2012, 09:32 AM
ALMOST STOCK
ALMOST STOCK's Avatar
Sounds like a possible vacuum leak. Have you checked to make sure you have all the vacuum lines hooked up?
ALMOST STOCK is offline
Old 04-08-2012, 11:31 AM
kevbaker1987
There all hooked up but when I was pulling the vacuum line off of the fuel pressure regulator that goes into the upper intake it snapped so I tried to use a different hose on it but still no luck. And what's weird is the antifreeze is over the full hot mark on the tank and I never added anything
Old 04-09-2012, 06:10 PM
stangman33
stangman33's Avatar
it sounds like a vacuum leak to me too. but maybe more or less around the intake itself. check to see of the intake gasket was messed up when you re-bolted everything back together. or that all the plugs were plugged back up/ could be something small and overlooked like a tps sensor.
stangman33 is offline
Old 04-12-2012, 10:50 AM
javila2468
javila2468's Avatar
I did the same thing you did and the Fuel PVC line was disconnected. This goes on the lower intake toward the firewall. make sure you bolted your upper and lower intake to the proper specs in and sequence. torque specs vary depending on your vehicle year.
javila2468 is offline
Old 04-12-2012, 10:54 AM
javila2468
javila2468's Avatar
the torque specs should be any where between 20-25 lbs on both lower and upper.
mstahoo
SVT Forums
08-19-2021 09:15 PM
ShaneB26154
35
03-04-2021 04:05 AM
mirandaandjimmy
11-16-2015 08:51 AM
Soldier GT
12
08-20-2015 09:42 AM
J.casone400
08-07-2015 08:40 PM
Quick Reply: car starts but dies right after
