Hi all I just got a 1995 Mustang GT Convertable and need to know how to accesss the left side door switch ,as the power windows are not reliably working... I do not have a shop manual yet-
first gently pry to the top of the plastic piece out towards you and you will see a small plastic tab that holds it in place. Once you have the top removed, then pull the entire cup up and there is another tension clips infront and behind the switches. Once it is out the switch is removed with two screws.
hopefully it is the switch but honestly the 5-wire wiring that controls the windows can be a little confusing to trouble shoot. What problems are you having?
The biggest is the drivers side window which in intermittent when I depresss the switch . Further regardless of (locked or not locked )the rear windows do not come down.
