Gas tank question.
Old 07-20-2012, 08:49 AM
FoRdBoY357
FoRdBoY357's Avatar
Default Gas tank question.
I'm building a 1997 track car with a carbureted Explorer 5.0 (So it's pretty much a 95 GT drivetrain-wise).
Will an old carb'd Fox body tank bolt in the place of the SN95's?
FoRdBoY357 is offline
Old 07-20-2012, 08:55 AM
dawson1112
dawson1112's Avatar
Im pretty sure the tanks were the same between 79-98
dawson1112 is offline
Old 07-20-2012, 08:57 AM
FoRdBoY357
FoRdBoY357's Avatar
Did the old ones have an in-tank fuel pump?
Old 07-20-2012, 09:28 AM
dawson1112
dawson1112's Avatar
It dosnt matter one way or another you just have to change the sending unit so that it is the old pick up type. I had a 95 mustang that i put a 68 carbed 302 in and all I did was change the sending unit out and run my 2 lines up to the mechanical pump. The tank was the origanal 95 tank. You can still use the electric fuel pump to if you get a fuel pressure regulator for a carb it just diverts most of the fuel back to the tank so you only get like 7 or 8 psi at the carb.
Old 07-20-2012, 12:28 PM
mattdel
mattdel's Avatar
Looks like the prices went sky-****ing-high on these, but I'm sure with some thrifty eBay'ing you can find one cheaper. Also, 86-97 tank wise.
http://www.latemodelrestoration.com/...et-Fuel-System
mattdel is offline
4cylinderplus2
10-09-2020 07:45 PM
Sixer4Life
10-12-2015 04:26 AM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Gas tank question.
