annoying squeal
Old 10-30-2012, 05:33 PM
leogravel
leogravel's Avatar
Angry annoying squeal
i just bought a 88 lx from a friend of mine and this morning when i started it the car started squealing.the battery light was flashing and went aw but the squeal is stil there.we just had a joke of a hurricane here in ma so i figured it was the belt.took the belt off and started car to see if it was a pulley and the squeal is stil there.so i know its not the pulleys or the water pump.it does it idling and moving so im kinda lost as to what it would be.any help would be awesome.
leogravel is offline
Old 10-30-2012, 06:40 PM
mattdel
mattdel's Avatar
video plz
mattdel is offline
Old 10-30-2012, 06:54 PM
dawson1112
dawson1112's Avatar
yep seariously put up a clip of the sound..Sometimes a vacuum leak can whistle loud enough to sound like a squeel. espesially if its leaking between the upper and lower intake the gasket can act like a reed
dawson1112 is offline
Old 10-31-2012, 05:33 AM
leogravel
leogravel's Avatar
Ok.ill get on that.
leogravel
leogravel's Avatar
It almost sounds like it coming from under the car
Old 10-31-2012, 06:35 AM
dawson1112
dawson1112's Avatar
well thats not good ... with no belt on it and a squeeling sound coming from under the engine Im hesitant to even have you start it long enough to get a sound clip of it. How was your oil pressure before all this started? Not to get you worried but a spun crank bearing will sometimes squeel as its burning up. But just to go threw a few other things here , if someone used an exhaust adaptor in the exahust pipes someplace Ive heard those whistle and sound like a squeeling noise as the exhaust passes over the lip of the adaptor. A bad throw out bearing will squeel also. I guess youll have to start it for a short period and try to pinpoint the location
Old 11-03-2012, 06:22 AM
leogravel
leogravel's Avatar
Pretty sure I figured it out.true other day I had no choice but to drive it to work.it was only a few miles so I went for it.I started it squeel was there.I drove down the road and heard a little pop and squeel went away.I went to start it later and the starter made a grinding sound I tried again car fired up.I tried to start the car later in the evening and it wouldn't start so I went to hit the starter with a hammer and it was moving.tightened it and no problems since.mabye the starter was loose enough for the nose cone to rub the flywheel?
Old 11-03-2012, 06:42 AM
darkmach1
darkmach1's Avatar
Ahhh, the hammer........the best tool in the toolbox.
darkmach1 is offline
Old 11-03-2012, 08:43 AM
dawson1112
dawson1112's Avatar
so no more squeeling?? probly was the starter rubbing a bit be glad it didnt destroy someting.
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
ccdguy
09-19-2015 05:20 PM
Cavedawg
09-17-2015 09:51 AM
tmdm
09-04-2015 06:45 PM
gus_vb
08-29-2015 11:35 PM
Quick Reply: annoying squeal
