Engine running rough
Old Dec 1, 2012 | 04:46 PM
Hawksfb08's Avatar
Hawksfb08
Default Engine running rough
I have a 95 mustang gt and I've recently installed long tube headers and deleted the smog system and now the car is running rough. At idle the car sounds almost as if it has a cam. Then when I accelerate the car sputters and jerks like it has a miss. Just to be clear I did plug the vacuum lines that go to the smog pump and have checked out all the other lines. All the ignition components where replaced about 15,000 miles ago and the only othe engine mod is cold air intake. There also isn't any cel. Any help would be greatly appreciated thanks.
Old Dec 1, 2012 | 06:38 PM
mattdel's Avatar
mattdel
Plug wires melted on the new headers?
Old Dec 1, 2012 | 06:51 PM
Hawksfb08's Avatar
Hawksfb08
Na I checked that out the other day I got all the plug boots turned up so there not near the primary tubes. Any other thoughts?
Old Dec 1, 2012 | 07:51 PM
94redGTConv's Avatar
94redGTConv
It doesn't seem like you've done anything to it for it to cause it to act thay way. Pull the codes. if you have any.
Posted from MustangForums.com App for Android
Old Dec 1, 2012 | 10:19 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
check the firing order...13726548 counter clockwise on distributor
Old Dec 2, 2012 | 12:01 PM
Duncan_GT's Avatar
Duncan_GT
YES. I did this when I tuned my car up last year. Had a couple of the plugs switched around, idled rough and did the same thing you are talking about. Ended up blowing the coolant radiator hose gasket that goes to the front of the lower intake manifold. Talk about a mess lol
Old Dec 2, 2012 | 02:02 PM
Hawksfb08's Avatar
Hawksfb08
I got it fixed a plug or two must have gotten messed up because I changed the plugs this morning and the car runs great thanks for all the input everyone
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
fdnyems19
Aug 13, 2015 09:36 AM
Jacob4589
Aug 8, 2015 11:00 AM
