393 Stroker
Old 10-04-2005, 12:53 PM
5.0_Cobra
5.0_Cobra's Avatar
Default 393 Stroker
Hello i need some help. i have a 89 5.0 aod that is a daily driver. I am building a 393 stroker. I got a block from my uncle which has been bored .030 over. I am going to use the 393 stroker kit from strokerkits.com. Im thinking about using the World Products R 200 heads and the EFI 351 GT-40 Intake. i want it to be streetable it will see the track every once in a while. i want to have a lot of low end torque so which cam, MAF meter, TB and fuel injectors should i go with. I was thinking 24 pound injectors, a 65mm TB, a 73mm MAF sensor thanks for all your help.
5.0_Cobra is offline
Old 10-04-2005, 06:07 PM
88BlueGT
88BlueGT's Avatar
Default RE: 393 Stroker
First, you are going to have to use bigger injectors than 24lb; I would go with a 70mm, and if you go with bigger injectors you are going to have to get a bigger MAF sensor. How much power do you really plan on this thing putting out. I would think that it would easily outdue 24 pounders.
88BlueGT is offline
Old 10-04-2005, 08:03 PM
5.0_Cobra
5.0_Cobra's Avatar
Im looking for around 350-450 hp and 400-500 tq. Would you go with 36 pound injectors and what cam? i want all the low end torque i can get.
Old 10-05-2005, 01:24 PM
tinman
tinman's Avatar
TFS twisted wedge heads. they will work good and flow plenty for the 393......
tinman is offline
Brett Ludlow
09-23-2015 06:59 AM
EASTIDEE123
09-14-2015 03:52 PM
YoungStangsMan
09-05-2015 07:01 PM
johan6966
01-28-2004 07:06 PM
Ifbbpro85
12-06-2003 03:19 AM
Quick Reply: 393 Stroker
