flywheels
using a heavy flywheel IE:billet steel will allow you to leave th eline harder due to the rotating weight of the flywheel.
using a light one IE: billet aluminum will allow the motor to rev faster due to the lighter spinning rotation
unless you race alot...use the aluminum
this is funny as hell..no don't use a alum flywheel on a street car.....on a stock engine it will tend to bog unless you rev it higher than normal..also between every shift rpm will drop faster because it can't build up so call energy to keep the R'S up between shifts...this is why stated above he has his rev's going up and down.....
ORIGINAL: chuck89gt
does anyone know if lightened flywheels are bad for your car if your motor is basically stock or should you keep the stock flywheel? someone answer for once please
http://www.hotrod.com/techarticles/43399/
https://mustangforums.com/m_424508/m...veshaft/tm.htm
junior04
Sep 28, 2015 10:53 AM
ccdguy
Sep 19, 2015 05:20 PM
