Just installed Clutch and its leaking Tranny fluid!!
Old 02-14-2014, 05:07 PM
camaroeater
camaroeater's Avatar
Default Just installed Clutch and its leaking Tranny fluid!!
Just finished up installing a clutch kit. I lost a bit of tranny fluid during install and filled it up in the fill hole until it dripped and tightened up the plug real good.
I took it for a spin and it feels great, but when i returned home I noticed it smoking a bit and there was a good size puddle of tranny fluid.
I did break the end of the speedo cable and left it disconnected at the trans....could that be the problem??
Please help! Thanks guys!
camaroeater is offline
Old 02-14-2014, 06:23 PM
dawson1112
dawson1112's Avatar
Yes that would be the problem , my trans leaked at the speedo cable as well until I replaced the pin that holds the cable in.
You should be able to tell if its coming from there .
dawson1112 is offline
Old 02-16-2014, 09:26 AM
camaroeater
It looks like what i broke/bent was the speed sensor. I don't have money for the cable right now, so I'm wondering if I can throw a new sensor in there and block it off or put a bolt in there with rtf.
Old 02-16-2014, 12:04 PM
camaroeater
Got it fixed....I broke just the speed sensor, not the speedo cable. I went and got a new sensor and threw it on without the gear b/c that broke trying to fix the old sensor.
Besides not having a speedometer for right now, the clutch feels like one on a new car.
I did a Ram HDX clutch kit with a new ford flywheel, clutch fork, pivot stud, rear-main, hardware, bearing retainer, pilot and throwout bearing. I also got a Maximum motorsports clutch cable with a firewall adjuster and an aluminum quadrant
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
antipeterleague
08-18-2015 01:50 PM
Greyshot
08-15-2015 03:32 AM
ponyride00
08-12-2015 01:57 PM
Quick Reply: Just installed Clutch and its leaking Tranny fluid!!
