low coolant
low coolant
for some reason my pony keeps losing coolant i dont see any leaks or anything. every two days i put coolant in so there must be a problem. somtime the coolant would look like its at the refill line in the bottle but tonight i was checkin it and the bottle looked completely empty.
RE: low coolant
Most likely it is a small leak that is evaporating before hitting the ground. Also, check your heater core for leaks, just turn the climate fan on heat and if you smell coolant then that is leaking. Beyond leaks the only other place for it to go is in the engine. Check the oil to see if there is any in there. Not sure how to check if it's getting in the combustion chamber, if it was it may not be enough to make any smoke or noticable smell.
jwog666
12-27-2021 08:09 PM
