Need Some Input On My T-5 Bearing Retainer Replacement
Old 04-26-2015, 10:29 PM
DanKoozer
DanKoozer's Avatar
Default Need Some Input On My T-5 Bearing Retainer Replacement
I'm replacing the original input bearing retainer with a steel unit I got from Summit Racing but the bolt holes on it are chamfered. The original bolts don't catch much of the housing. A phone call to Summit didn't offer any solutions.
Anyone?
Thanks,
Dan
DanKoozer is offline
Old 04-26-2015, 11:36 PM
jwog666
jwog666's Avatar
if there is a good ammount of threads, i would just use a flat washer under each bolt, easy peasy
jwog666 is offline
Old 04-27-2015, 06:48 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
THAT IS OF NO CONCERN.......more so you should set the preload via the shim behind the race properly......start with using the oem shim and go from there. use a small washer on the bolt and a tad of blue loctite if it worries you.
mjr46 is offline
Old 04-27-2015, 12:05 PM
dawson1112
dawson1112's Avatar
Yea I think when you change the bearing retainer that's the most important step is making sure your bearing preload stays with in spec.
dawson1112 is offline
Tivo304
08-28-2023 12:19 PM
5.0muscle
01-11-2016 01:17 PM
Golfsito
10-06-2015 11:02 AM
04stangman
09-17-2015 01:45 PM
09-08-2015 11:50 AM
Quick Reply: Need Some Input On My T-5 Bearing Retainer Replacement
