1995 mustang 302 build help
I'm building an engine for a 1995 mustang, but the engine I am rebuilding is a 1984 out of a Lincoln mark VII, I want to know what parts I need to change for it to fit in the new car, (car is a 1995 mustang v6 with a t5) I've heard about needing a different timing cover? Anyway, your help is appreciated!
make sure the block is roller ready....if it's a flat tappet block, you can't just swap it in yours........the lifter bores in a flat tappet block are shorter and you can just throw a roller cam in a non -roller block..........1 of two ways........well actually only one correct way = use 365 dollar morel link bar lifters and any roller cam of your choice ground on the standard base circle.
I feel like I'm aware of most of the engine specific things, I'm looking for info on fitting it into the car, I'm looking to put a carb on it, do I need a specific oil pan? Different engine mounts? The mounts I have are from a mark VII which is a foxbody platform, etc.
Because the oil pan an engine mounts are car specific, I know that my engine will drop right into a foxbody (although it being a flat tappet block) but I am not sure what I may need to change for it to fit in the early sn95 platform.
