Gain 100 to 115 horses
Old 08-17-2015, 08:58 PM
64bit
64bit's Avatar
Originally Posted by 88 orangepeel notch
Show off !!!................lol
Edit: That was meant for 64
You like that?
64bit is offline
Old 08-17-2015, 09:49 PM
88 orangepeel notch
88 orangepeel notch's Avatar
lol, someday when I pop the hood, I hope to see a similar setup.
Last I read, you had some final tuning / tweaks left to do yet, have you got it dialed in yet ?
88 orangepeel notch is offline
Old 08-18-2015, 12:07 PM
64bit
64bit's Avatar
Installed a new turbo and finally got the transmission issue sorted out. Made some part throttle pulls and pegged my MAF. Boost went up to 15 from 10 after the turbo swap. I'm waiting for a few more parts for the new intake. I had to upgrade to 3.5" piping because the 3" housing was obviously too small.
Last set of datalogs showed the car pulling over 2600kg/hr of airflow. Wasn't even a full pull, let off at 5300rpm. For comparison purposes... my old 347 made 418whp and peaked at 1250ish kg/hr airflow.
64bit is offline
Old 08-19-2015, 06:58 AM
88 orangepeel notch
Soooo,......what your saying is this motor should hit 420 - 425 ???
lol.
Should be some crazy numbers when your done. Good luck
Sorry for the hijack OP.
Old 09-01-2015, 01:19 PM
luckythirteen13
luckythirteen13's Avatar
go turbo and be done. itll idle like stock, itll cruise like stock, itll get stock MPG but when you hit the gas, hold on.
luckythirteen13 is offline
Old 09-01-2015, 02:12 PM
Granatelli Sales
Former Sponsor
Granatelli Sales's Avatar
A good top end should get you there. You will also need some supporting hardware Like mjr46 mentioned. The Trick Flow kit is a good place to start because it has pretty much everything you will need. You could also build your own top end kit with other components if you aren't a fan of TFS. I would say the only downside to the TFS kit is that the heads are not CNC ported.
You will need to upgrade you fuel injectors, MAF sensor, and fuel pump to compensate for the greater fuel demand.
You may also want to add a bigger throttle body and EGR spacer, headers and new roller lifters as the TFS kit does not include them.
Dyno tuning may be needed for best performance.
Granatelli Sales is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
Explosive
10-02-2015 07:45 AM
mdg
10-01-2015 07:04 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Gain 100 to 115 horses
