Which head gasket?
Which head gasket?
I am in need of a set of head gaskets and want to go with felpro being that is what was on it and worked awesome. I have a 86 gt with stock pistons e7 heads so you know i have little clearance. i was thinking of going with the little thicker compressed gasket to help with clearance. let me know what you all think and give me some part #'s if you dont mind.
RE: Which head gasket?
do you think i should notch the pistons now. it looks like they already are. there is a little groove cut on each piston. I have heard of using a die grinder and grinding valve releif. but i wouldnt know how much.
ORIGINAL: ZachW04Stang
It might you enough for a little clearance but don't expect to be able to install a cam or large valve heads without notching the pistons.
