What speedo correction gear do I need?
RE: What speedo correction gear do I need?
last time i checked though svt only sold the short nipple 23 tooth. which is for the 5 speed ,i may be wrong though.5.0 resto sells a long nipple 23 tooth for aod.
http://www.latemodelrestoration.com/...t_50_home.aspx
part #lrs-17271j
part #lrs-17271j
ORIGINAL: 1991_5.0_Convertible
Lemme rephrase my question, where can I buy them, I looked on 50resto.com and they didn't have any for 3.73 gears for a 91 AOD.
they don't exist, you need to pull your trans apart and replace the drive gera, which is machined onto the output shaft.
so you need an older output shaft , yours has an 8 tooth drive and whatever driven for your stock combo.
you need either a 7/21 combo or a 6/18 combo (drive/driven resp.)
or you can go to a speedo calibration shop and have a "box" built. either way it's gonna be about a grand, unless your gonna tear apart the tranny yourself
EDIT ******* i should have read all these posts, the one from steeda IS NOT correct for you. w/ your drive gear you would need about a 25 tooth driven which obviously does not exist. the 23 tooth gears are from mopar, and they are white. it's a jeep part. they are also a different pitch from an aod, and will last about 10k miles at most, and still gonna be close to 10% off
no get what you want, i never correct my speedo's , you get used to it.
depending what size your tire measures out to (how tall) the 3.73's wouldn't actually be all that bad as far as error.
i would never do 3.55's in an aod. you would hardly notice a diff, if you have 3.27's currently, you won't notice much going to 3.73's and will wish you went 4.10's. in the door tag, check ax code, z=3.08 and e=3.27 m=2.73 but i don't think they put 2.73's in a aod at all.
273 was standard gear for either AOD or T5 cars
327 was optional for AOD
308 was optinaol for t5
my first 89 GT had 273 gears it was a dog!!!!!!!!!!!
my 88 hatch had 327, now 410
my 88 notch had 308, now 355
yeah i wasn't sure, both my aod's were 3.27 and all 3 5-speeds were 2.73
and trust me even the 3.27 was slow in the aod. 4.10's all the way , i would never use less.
KingRando
10-02-2015 08:06 AM
273, 373, 410s, 50, 89, 92, 93, correction, foxbody, gear, gears, mustang, spedometer, speedo, speedometer
