dry kit???
dry kit???
i have a zex kit for my 5.0 and i was wondering how a dry kit works i know it uses you fuel injectors and the vac to the fuel regulator and theres nitros pills and ones that are called fuel pills but the go through the vac. so the quetion is how does it give the car more fuel if at open throttle even with on the nitros the fuel pressure regulator is at no vac i dont get how it would know to give the car more fuel????
RE: dry kit???
the vac line HAS to be on or it will just stay at about 42 psi
the "fuel" jet is actually the "vac" jet, but since it's used to bump the fuel pressure, they call it the fuel jet.
anyway, just like the bigger jet allows more nitrous to spray, the bigger vac jet cretaes a higher fuel pressure.
if you could see inside the zex box as separate components, it's like the NOS kit. of the nitrous reg, is where the vac line comes off,then runs to the fp reg. and when the nitrous sprays, it causes the change in vac, which spikes the fp.
i can't really explain it any better , especially since the jetting combo doesn't always go w/ bigger and bigger......the jets for a 150 shot are the reverse of the 75 shot....just reversed....#67 and #42 (which is .067 and .042) but thats the idea anyway
jwog666
12-27-2021 08:09 PM
