Resurrecting the dead...
RE: Resurrecting the dead...
ummmm... ok? Anyone else have any USEFUL, PRACTICAL, and ACCURATE input?
I'd like to go EFI because of throttle response and ease of configuration. The last time it ran, it had a Holley 650 double pumper. It screamed in its own right... ate up plenty of Camaro's, Corvettes, and even a few other ponies (most of those had no clue how to drive!).
I just like the idea of being able to set all of the engine configurations through a computer rather than twisting the distributor and turning the fee screws on the carb, guessing that I'm even getting it close to where it should be.
Hey chord,
Not sure but if this EFI system is programmable it would seem to suit your increased displacement needs, particularly if you can change the injectors themselves. Modding the intake system might be needed to increase volume as well but should be doable.
Good luck with the project.
ORIGINAL: Nemesis
Hey chord,
Hey chord,
Ideally, I'd like to find the GT-40 heads and intakes from an Explorer and take a complete EFI from a late model Fox Mustang. On paper, it looks good and I haven't seen anything that says it won't work.
I'll build the block up with forged internals and prep it for turbochargers. After that, I'll build up the suspension and chassis and tackle the interior after that. Lastly, I'll see about scavenging some turbos from a turbo t-bird or cougar and piece together a twin turbo setup. My goal is to have an aggressive daily driver that does well at the track (low-mid 12's would be nice!).
EDIT: Didn't take a whole lot of digging. Read on:
We were getting ready to do this while trying to put a 351C in my son's 93 Lightning. We decided against the swap but not because of the fuel injection issue. Thers is a company in Indiana making adapter plates that will allow the use of 302w intake manifolds on a 351C. The name is Price Motorsports, and this allows you to use a stock 5.0 Mustang fuel injection computer and sensors instead of trying to make an aftermarket unit work. The fuel injection doesn't know what engine it's attached to, it just measures air flow and adds gas.
Originally quoted by http://www.network54.com/Forum/11941...6/cleveland+FI
Unless someone has other information, I'm going to consider this solved.
I don't know much about doing a carb to efi swap but you won't be able to use a 302 intake manifold on a 351. The 351's intake is wider then the 302s but everything else should swap over.
ORIGINAL: vfast
I would just stay carb..alot less headache.....and cheaper....
[hr]
Goal:
[ul][*] Full resto of my 1985 GT w/T-tops[*] Rebuilt (possibly stroked) 351W with forged internals[*] Complete EFI swap[*] Twin turbo setup[*] Full chassis and suspension upgrade for street/strip application[*] Rear disc brake conversion[*] To do all of this using as many junkyard pieces as possible without compromising safety
[/ul]
