compression ratio
RE: compression ratio
ORIGINAL: hardcore91LX
what is the highest compression I can run on 93 octane with no problems on the street.
Correct on the cam influence, and don't forget elevation too. If you think you are borderline, do a compression test. I've heard you should not exceed 180 psi cranking if you want to stick to premium pump gas. This takes into account all factors mentioned above and before.
uberstang1
09-20-2015 06:42 PM
