Help me build a motor
#31
RE: Help me build a motor
I have the TW heads on my 347 and I think they are great.
I have a Hawks racing forged crank ~ $400
I have SCAT forged H beam rods ~ $300
Just make sure you get forged dished pistons made to match with the TW heads. It does take a different piston. Trick flow forged pistons ~ $450 or Probe ~ $400
ORIGINAL: Tims 88GT
ok well the only thing wrong with the r302 block is that it is a race block and does not cool as well, i was looking into that and its not what i want, this is my DD car so it has to be built good but not get hot and stuff like that, and im dead set on trick flow tw heads unless someone comes out with something better before i build this motor. what crank do you suggest? thanks for the help
#34
ok the set up i want to run is a lot like my nabors that is where i got the idea, because everything works so well with his car. he has stage 1 ported TW's a edlebrock performer intake, r302 block, ross pistons, manly rods, egale crank, i do now know what cam. its a 347 stroker, with 10psi from a vortec.
#35
Many combinations work great. Did you see my vid of my 86 GT 347? I also have a 306 that made 450 RWHP with the stock crank and rods.
ORIGINAL: Tims 88GT
#39
Whoa, wait a minute.
My 306 made 450+ hp on an engine dyno in Tucson AZ.
I use the Ford block out to 306CID
Forged crank/rods. Use the 'H' beams, use good bolts in the rods.. Use the flat top pistons and abot 58cc TFS twisted wedge heads (2.02X1.60)
Balance everything............
Vic jr. intake portmatched to heads. Modified BG 650 Carb.
Bassini step headers.
I've never mentioned camshaft. Hyd. roller, 1.6 rockers. Refse to give up too many secrets........
I use lots of care/carefull fitting of everything . Just like this was some sort of super/stock or something.......
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
logan409
09-26-2015 07:43 PM
