HP numbers on a stock motor with an s/c
Old 01-07-2006, 10:01 PM
Tims 88GT
Tims 88GT's Avatar
Default HP numbers on a stock motor with an s/c
Someone asked this question and i knew the answer but i was not certin on the numbers but here it is, All stock motor, makes 373.1hp and 510.9 ft lbs of twist at the rear wheels with an AOD @ 14psi. it runs 10.91 @17psi
Power adder
Vortec v-1 s trim
14psi at 5,600rpm
EXHAUST
bbk 1 5/8 shorties
bbk h-pipe o/r
flomaster 2 chamber mufflers with tail pipes
FUEL
walbro GSS 342lph in tank pump
42lb injectors
kirban afpr
TRANS
Stock AOD never opened
Precidion Industries 9.5 converter
with 4k stall
Rear Stock with 3.73
Tims 88GT is offline
Old 01-07-2006, 10:26 PM
hatingyou
hatingyou's Avatar
Default RE: HP numbers on a stock motor with an s/c
You have a dyno graph? I just want to see the torque curve, that is a pretty beastly number for the stock motor.
hatingyou is offline
Old 01-07-2006, 10:28 PM
Suspect
Suspect's Avatar
torque # has to be off.
Suspect is offline
Old 01-07-2006, 10:37 PM
marx91
marx91's Avatar
the hp seems reasonable, that tq. # is a little high, that looks like a tq# from a nitrous hit not a blower
marx91 is offline
Old 01-07-2006, 11:03 PM
Tims 88GT
Tims 88GT's Avatar
look up Tim Stockwell that will show you the same thing. i thought the same thing, but i think they have a dyno graph, i only have the info in the December 2004 issue of 5.0 mustang and super fords. hope this helps, if it is true that is one heck of a tq number
09-01-2015 08:16 PM
kawiguy827
09-01-2015 07:09 PM
GimpyHSHS
08-29-2015 06:30 PM
Jacob4589
08-17-2015 09:34 PM
Soldier GT
08-12-2015 03:46 PM
Quick Reply: HP numbers on a stock motor with an s/c
