GT-40 upper/lower
Old Jan 20, 2006 | 01:10 AM
Kbush723's Avatar
Kbush723
Default GT-40 upper/lower
might be a dumb question but.. well i dont know.. and i figure one of you know.. ..
cant a upper and lower mate with stock heads ..?
with that said can trick flow upper and lower mate with stock heads..?
Old Jan 20, 2006 | 01:43 AM
FullAuto's Avatar
FullAuto
Default RE: GT-40 upper/lower
They both fit stock heads.
Old Jan 20, 2006 | 03:49 AM
Crazyfast50stang's Avatar
Crazyfast50stang
ORIGINAL: FullAuto
+1
Old Jan 20, 2006 | 04:21 AM
groundpounder's Avatar
groundpounder
Sith Lord/Site Mod
ORIGINAL: Crazyfast50stang
ORIGINAL: FullAuto
+1
+eleventy billion. BUT...
Do a dry run fit on them and choose your gaskets carefully. Somebody help me with this but I think the de facto gasket is Fel-Pro #1250, generally recognized as the best fit.
Having said that, though, doing a dry gasket fit will help you de-burr the edges (I would chamfer the intake runners maybe an eigth) and port-match the intake runners on the lower intake to the gasket/head. There is ALWAYS room for improvement there, even though Trick Flow has real nice castings. Depending on how much work you want to do (and I assume you are not taking the stock heads off), you could easily unlock another sneaky 10-20 free horsepower here, especially if you want to true up the throttle-body orifice on the upper and split hairs by port matching the upper and lower with a 1" spacer in between. Not a lot of people do this because it is a lot of sweat equity and you're already going to see gobs of gain over a stock intake, but if you want to squeeze blood out of the horsepower turnip, it's well worth the time.
Old Jan 20, 2006 | 04:54 AM
92hatchLX's Avatar
92hatchLX
That was, wow, a moving article... Good info btw.
Old Jan 20, 2006 | 08:19 PM
groundpounder
Sith Lord/Site Mod
ha ha!!
gp = full of hot air (and don't I know it!!)
GimpyHSHS
Aug 29, 2015 06:30 PM
inyadreems
Aug 21, 2015 09:10 AM
94Cbra
Oct 8, 2004 07:00 AM
90Mustangfan
Aug 4, 2004 08:11 PM
neestangk
Nov 4, 2003 10:14 AM
