AFR heads valve geometry?
Does any one in here know if the AFR 165cc heads have issues with pushrod length? Also, what washers/spacers are neccasary to install them on a 289 with 7/16 head bolts? Do you really need to run the Fel-Pro race head gastkets required by AFR? I have the 61cc. Thanks a lot !!
Brett
Brett
RE: AFR heads valve geometry?
i didnt have any push rod issues. you have to get hardened ones. i got stock legnth. dont know of any spacers. you can run any gasket you want, they just recomend fel-pro
Luckythirteen do you have 1/2" head bolts or 7/16? I have a 289 and they use 7/16 head bolts and the AFRs are drilled for 1/2" bolts. I have heard of using washers or sleeves on the 7/16 bolts. Also, is pushrod length extremely important? Can I just get some in the ball park and adjust the valves to them? Right now i have E7 heads on a 289 and im using stock pushrods for a 289 not 302. What do you suggest i do about pushrods? Thanks for your time..
Brett
Brett
i know what you are talking about..afr's can be used on 351's so thats why you buy the head bolt retainers.
which are like sleeves...and yes it does make a diff on what your push rod length is...you can look it up on afr's site also.
ORIGINAL: bleedfordblue65
Brett
Brett
