Roller Rockers
Old 02-02-2004, 02:51 PM
Red5Ltr
Red5Ltr's Avatar
Default Roller Rockers
<DIV>I purchasing a set of heads for my mustang that are set up for pedastal mount rockers. I want to put a set of rollers in and I'm uncertain of the correct ratio to use. I see people using 1.6 and 1.7 and I get why from a spring load perspective, but is there any other reason. I have a E303 cam in the stang. Also what are a good set, but won't set me back $200-$300 buck?</DIV>
<DIV></DIV>
<DIV>Thank you,</DIV>
<DIV></DIV>
<DIV></DIV>
<DIV>John</DIV>
Red5Ltr is offline
Old 02-02-2004, 04:49 PM
vfast
I ♥ Acer
vfast's Avatar
a new set will set you back about that much try finding a good used set
vfast is offline
Old 02-02-2004, 04:50 PM
619socalstang
619socalstang's Avatar
www.summitracing.com will answer all your Q and got good daels on roller rockers. just tell them what you got and theyell hook you up in the price range, get 1.6 for simplissity.
619socalstang is offline
Old 02-02-2004, 05:48 PM
mkspeed26
mkspeed26's Avatar
www.summitracing.com = <IMG src=smileys/smiley4.gif border="0"></P>
1.7s give you more valve lift than the 1.6s</P>
mkspeed26 is offline
Old 02-02-2004, 08:06 PM
Milky
Milky's Avatar
1.7's give you about .30 more lift than the 1.6s will. I dunno the specs on the e303 but 1.7s probably would do you fine but like socal said go with 1.6 for the simplicity of it ...
Milky is offline
Old 02-02-2004, 08:15 PM
T5superduty
T5superduty's Avatar
Originally Posted by Milky
I dunno the specs on the e303 ...
</P>
It would give youbasicly.525" -.530" lift cam</P>
T5superduty is offline
Sixer4Life
10-12-2015 04:26 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
uedlose
09-30-2015 08:01 AM
Sixer4Life
09-28-2015 07:05 AM
JDWalton
09-24-2015 08:47 PM
Quick Reply: Roller Rockers
