Bigger Tires
Old Feb 9, 2006 | 12:41 AM
ZoSo15's Avatar
ZoSo15
Default Bigger Tires
I was just wondering what size tires i should get for my car. whats the biggest size that will fit? how big should i go with 4.10s. i think im gonna keep the fronts 235/55R16 but i definitely need bigger ones for the back
Old Feb 9, 2006 | 01:01 AM
Blue Oval's Avatar
Blue Oval
Default RE: Bigger Tires
well what size are your rims?
Old Feb 9, 2006 | 01:05 AM
ZoSo15's Avatar
ZoSo15
uh, they're the stock pony rims. idk they might be 16x7 but idk
Old Feb 9, 2006 | 01:07 AM
Blue Oval's Avatar
Blue Oval
thats what i have too, and i have 245 in the back, you cant go much bigger than that so look for sticky tires or street radials
Old Feb 9, 2006 | 01:18 AM
ZoSo15's Avatar
ZoSo15
Think 255 will work? and is the second number supposed to be the width?
Old Feb 9, 2006 | 01:22 AM
Blue Oval's Avatar
Blue Oval
the 2nd number is the aspect ratio, its how tall the sidewall is in percent of the tread width (first number) you could try 255 but its probably pushing it and you wont get all that to the ground. it will kinda look pear shaped like when a fat chick sits on a chair; kinda hard to explain
Old Feb 9, 2006 | 02:09 AM
Ecstasy's Avatar
Ecstasy
i have 225/60/16s right now, but whenever i fix that front right side, either an alignment will fix it, or i need to replace the k-member or k-arm w/e its called or the strut, so that way it wont rub on a sharp right turn. im going to go with like 245/50/16s.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
