cam & injector questions
What is the difference, if any between the 1995 GT cam and the 1995 Cobra cam? 2. What horsepower level are the stock 19# injectors for. I just picked up a 95 non running cobra today for a good price and have some good parts that came out of my 95GT sitting around. Thanks in advance for any info.
RE: cam & injector questions
^^^was that w/ a tune? I know people that use 19's up to ~300rwhp.
the cobra has 24's, but if i remember correctly, the MAF is calibrated for 19's and the computer adjusts it....
I do believe the cams are the same, but the cobra has GT-40 heads and cobra intake, as well as a larger TB and MAF.
ORIGINAL: OnyxCobra
cobra cam has a larger lift and also 1.7 RRs
I.O./I.C./Lift 20°/76°/0.278
E.O./E.C./Lift 67°/19°/0.278
Duration - Int/Exh 276°/266°
Valve Lift - Int./Exh. (1.6 rocker arm ratio) 0.444"/0.444"
Overlap 39°
Only the 93 Cobra cam was bigger, F3ZE-6250-CA
I.O./I.C./Lift 19°/71°/0.282
E.O./E.C./Lift 75.5°/14.5°/0.282
Duration - Int/Exh 270°/270°
Valve Lift - Int./Exh. (1.7 rocker arm ratio) 0.479"/0.479"
Overlap 33.5°
The question was about 1995 only
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
