engine bogging down when gas t
Old Jun 12, 2003 | 12:24 PM
  #21
WhiteHawk's Avatar
WhiteHawk
Default engine bogging down when gas t
DrededSS,</P>
"The only rule she has is that I can't get on it with her in the truck"</P>
I must be slow today....."get on" what?</P>
(redhead....mmmmm) so true! </P>
</P>
Old Feb 10, 2008 | 10:42 PM
  #22
bvoytekb's Avatar
bvoytekb
Default RE: engine bogging down when gas t
I have a 93lx 5.0 and i have the same problem. I unhooked the tps and the car runs like a champ. Has anyone found the correct fix for this problem?
Old Feb 11, 2008 | 12:33 AM
  #23
lubbockoldskool's Avatar
lubbockoldskool
my 89 has a similar problem, only ive replaced tps, fuel pump, fuel pressure regulator, distributor, spark plugs and wires
and still if im coasting it will die.....if its running and i give it gas it will cough choke then boom...power so now im on to a new ecu hopefully that will fix it
Old Feb 11, 2008 | 10:21 PM
  #24
lubbockoldskool
you would never believe it but putting a new ecu fixed my problem.....the problem was that somebody had taken the ecu braket out and so it was hanging and flopping around, which eventually nocked everything inside all to hell so the new ecu and alot of other money for stuff i didnt need and its fixed
Old Feb 11, 2008 | 10:57 PM
  #25
aode08's Avatar
aode08
What did you gap your spark plugs at?
Sounds like you have two wires in the wrong place?
Check the tip of your coil pack, where the plugs wire is on at, remove the plug wire and try to move the silver tip with your hand, if its loose, repalce the coil pack, even if it turns.
Here, now fix that man,
Fig. 3: 5.0L Engine Engine Firing Order: 1-3-7-2-6-5-4-8 Distributor Rotation: Counterclockwise
Old Feb 12, 2008 | 07:09 AM
  #26
cholericfc's Avatar
cholericfc
replace fuel filter, and do "Idle Setting Procedure" that FORD can give you..........YOU MUST do this procedure when you do those kind of mods to your car
Old Mar 29, 2008 | 11:18 AM
  #27
PDUB2025's Avatar
PDUB2025
I'm Running around in a 93 ford probe having the same issue... it wasnt so bad until i replaced the clutch and transmission ( although the trans did come from a junkyard) before the transmission swap al i did was fiddle with a screw on the air intake and it worrked... alright at times.. but still couldnt punch it like i wanted to... and now i have to slowly apply the gas and ive come to realize how grandma feels when i ride her ***... i havent tried the tps yet and i have absolutely no money for a new anything... but my question is.. if i take the tps sensor cable off.. and just drive like that.. will it be ok?
Old Dec 15, 2008 | 03:20 PM
  #28
1996 GT's Avatar
1996 GT
i have the same problem but it boggs out and i feel a loss of power when i drive normal but when i floor it it hooks up and drives fine. any suggestions?
cardsrus1
19
Sep 15, 2015 08:37 AM
algregory
Sep 11, 2015 11:44 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
zachary1988
Sep 4, 2015 03:04 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
