T-5 Swap Complete. Rattling in bellhousing??
I finished up my swap this evening and when the car is running and in neutral or in gear and driving, there is this rattling sound coming from the bellhousing so something is not quite right. Now, when I apply even the tiniest bit of pressure on the clutch pedal the rattling quits, which makes me think it might just be a cable adjusment issue. There's only a few things it could be, and I'm sure I can figure it out, but I was wondering if anyone else has had this happen. It's either cable adjustment, throwout bearing is a piece (even though it's new.) or the little springy clips on the clutch fork aren't holding the bearing and are rattling against it. But that doesnt' make much sense to me since the bearing sits pretty loose in the clips anyway. Any input from anyone who has ideas would be great.
RE: T-5 Swap Complete. Rattling in bellhousing??
When i did mine i had used the lakewood blow proof bellhousing and i no longer had that problem but when mine did rattle with the stock one it was the clutch fork fatleing because there was not enough tension...if that helps any
Matt's 95 Stang
10-05-2015 07:16 AM
