Dirty MAF?
I heard some talk of people having trouble with dirty MAFs. I'm not talking about the chump that stole your girlfriend that summer; I'm talking about the sensor.
My car idles a bit rough sometimes (and uses a bit more gas than I'd like), even after a complete tuneup. I'm just starting to consider that it is either my MAF or O2 sensors. Do MAFs ever need to be cleaned? Thanks again.
They do get dirty and can be cleaned. But be very careful not to break the wires. I take a biss card and tear the corner off and use this to clean the wires. Not a big piece just about a 1/4 inches from the corner small piece and wipe the wires off. Just be carefull and you should be fine.
If you want to test your MAF then TAP it with a screw driver and if your RPM's start to change then its your MAF. I believe your engine light would come on if you had a problem with the O2 sensor but you can lways try it anyways. Its wierd when I disconnect my batter froa bout 15 minutes I will get better gas mileage, thats after I change something on the car.
i use a qtip and some electronic parts cleaner its near ur right hand inner fender mine had two ant-itamper torx head screws holding it down just unplugg it and unbolt wipe gently with a qtip!
ORIGINAL: 94Cobrakid16
my car idles rough and i get bad gas milage too, my maf has prolly never been cleaned, and i dont know how to.
How do you clean it? i got the biss card thing but where is it
jwog666
Dec 27, 2021 08:09 PM
stangin1996gt
Sep 21, 2015 11:01 AM
