Yeah so
Old May 30, 2007 | 06:16 AM
SuperFox88's Avatar
SuperFox88
Default Yeah so
I had to switch to mustang 4 cyl springs up front. The nose was sitting about 3 inches above the rear. Switching to the springs have helped me out a lot with hooking on street tires. It will actually transfer weight now. So far i have taken a bunch of weight off of the nose. I moved the battery to the back, took out the sway bar, cut out the hood brace, took out the front bumper and mounts, removed the smog pump, A/C, and power steering. Thats really about it so far. I meen the interior is gutted behind the front seats. It weighs in at 2900 lbs even. I still have a bunch to take out. Just a few suggestions for yall.
Old May 30, 2007 | 06:18 PM
Hurricanedt77's Avatar
Hurricanedt77
Default RE: Yeah so
Since you are now lacking a front sway bar, have you noticed any difference in ride quality on the highway. Or under any driving circumstances. I was thinking of doing the same, but I want my car to handle when I need it to.
Old May 30, 2007 | 08:05 PM
93 LX FiveO's Avatar
93 LX FiveO
Default RE: Yeah so
keep the sway bar
Old May 30, 2007 | 08:12 PM
gearbanger's Avatar
gearbanger
Default RE: Yeah so
ORIGINAL: 93 LX FiveO
keep the sway bar
yea+1 corners will suck realy bad if you take it out
Old May 30, 2007 | 10:27 PM
ford91mustang's Avatar
ford91mustang
Default RE: Yeah so
get some before and after pics if you got em...how much lower is the front end?
Old May 30, 2007 | 10:42 PM
91hatchgt's Avatar
91hatchgt
Default RE: Yeah so
I removed the front sway bar on my 91 GT, it handles nice still but it was lowered 2" all the way around. If the car is at stock height, I bet it would have been a lot more squirrley. Just keep it on, it doesn't do much.
Old May 31, 2007 | 12:24 AM
Valcore's Avatar
Valcore
Default RE: Yeah so
I hate my ride height!!! the front is like an inch higher than the back. I hate it so much!
Old Jun 5, 2007 | 08:09 PM
SuperFox88's Avatar
SuperFox88
Default RE: Yeah so
It hasnt really sacrificed my cornering to much. I meen it is different but not to bad. It was, like i said about 3 in higher than the rear, now it sits about an inch lower since i switched.
Old Jun 5, 2007 | 10:04 PM
LTnone's Avatar
LTnone
Default RE: Yeah so
Mine sits up a bit higher now with the aluminum heads and trunk mounted battery. No me gusta[:'(]
Old Jun 6, 2007 | 12:39 AM
dimebag's Avatar
dimebag
Default RE: Yeah so
yea... for the record, and just for another 1st hand opinion. i have NO SWAY BAR, 4banger springs and strange struts... it handles better then stock w. the struts tightened down... w. them loose its like a boat. but its still not bad at all.
MasterLanMan
Sep 13, 2015 08:21 PM
Aug 13, 2015 08:06 AM
l2olVlaN
Apr 20, 2004 08:43 PM
04SonicGT
Apr 5, 2004 02:51 AM
66_mustang_04
19
Mar 27, 2004 12:18 AM
