bondo
Old Jun 16, 2007 | 11:50 PM
stanglx2002's Avatar
stanglx2002
Default bondo
For guys that have been working with bondo for awhile. I have been looking the temperature specs of bondo. I would like to know how much heat can bondo handle such as an engine bay. I have pretty much all the holes in my project cars engine bay welded up and I wanted something that I can use to smooth over the whole engine bay such as bondo that can with stand the high temperatures with cracking. Does anyone know if bondo will work or not and if not what can I use????
Old Jun 16, 2007 | 11:52 PM
87ttopGT420's Avatar
87ttopGT420
Default RE: bondo
bon-don't
Old Jun 17, 2007 | 12:23 AM
stanglx2002
Default RE: bondo
then what do I use then
Old Jun 17, 2007 | 03:36 PM
stang8689's Avatar
stang8689
Default RE: bondo
I used mar glass which is a thick biberglass fill. Then used bondo over top that, just a little bit to smooth the glass. Check my tread on this page about smoothing engine bay, got finished pics
Old Jun 17, 2007 | 04:17 PM
ALMOST STOCK's Avatar
ALMOST STOCK
Default RE: bondo
I was told to use all-metal!
It's been over 7yrs and not one problem to date.
Old Jun 17, 2007 | 10:34 PM
stang8689's Avatar
stang8689
Default RE: bondo
yeah almost stocks engine bay is sweet, once you weld all the holes just give it a skim coat of bondo to smooth it out, its when you put it on thick where it will crack
Old Jun 17, 2007 | 11:55 PM
stanglx2002
Default RE: bondo
Where did you get the mar glass from???
Old Jun 18, 2007 | 12:50 AM
stanglx2002
Default RE: bondo
what do you recommend doing just bondo or mar glass and bondo???
Clu7ch
Jun 6, 2006 02:08 AM
Littlepepe27
Mar 23, 2006 06:21 PM
Littlepepe27
Mar 23, 2006 02:55 AM
mustang_montana
Aug 21, 2005 03:13 AM
tron
May 12, 2005 02:53 PM
