tire rub
tire rub
ok so i wrecked my 89 gt. it was nothing major just fender and bumper. so i finally got my new ones painted and put on but when i put my new ponys on they rub. they only rub up front. 225/55/16. the frame and supports are straight. any suggestions on how to make them not rub?
RE: tire rub
they rub on the fender. not a lot but enough to make me take them off until i get everything right. i thought that 245 should even fit with no rub. so i still need to pull the front supports forward?
RE: tire rub
Which fenders are you using? 79-90 or 91-93? The front fender spat (the scoop) was made a bit smaller in front for 91 so the tires wouldnt rub. Using a 91-93 fender with the 87-90 spat could cause a problem. The spat will be pushed closer to the tire.
The bs on my 16" Ponys are 5.72 if i remember correctly. All 4 are a 225/55/16 BFG. No rubbing of any kind anywhere. Then again my 93 came with them.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
