grant wheel
grant wheel
whats up fellas ... im about to do this tilt wheel conversion on my 93 .. just wondering if you guys have any tips on installing the grant wheel ... i have the formula series 771 model wheel ... im wondering about the spring .. do i remove the old one and replace it with the new one and attach it to the hub that came with the installation kit then just slide it onto the shaft ? Anyone have alignment problems after installation ? will i need to get a wheel allignment??
RE: grant wheel
I'd also like to swap to a Grant wheel on a tilt column ('89 column). Subscribing to see what others have used for an adapter, clock spring, and surrounding trim. Pics would be great! I want a nice clean install.
RE: grant wheel
you need the installation kit part number 3289 .. about the trim peices .. if you already have an 89 column in your car you should be able to reuse your trim peices .. if you have a 90-93 car you have to buy 87-93 trim peices
RE: grant wheel
Cool, thanks.
I just didn't want to see any gaps or holes. I've seen a few cars with aftermarket steering wheels that looked pretty hacked.
Mine's an '83 with a '93 interior swapped in, then the '89 tilt column was swapped in later. Has the '89 column trim and instrument cluster shroud too.
RE: grant wheel
well hopefully ill have mine done in the next 2 weeks if this dam column ever arrives ... ill post up some pics of how it came out
ponyboy30250 - Photobucket - Video and Image Hosting
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
