price on trick flow twisted wedge heads???
RE: price on trick flow twisted wedge heads???
and this we knewoh hey adder...86 non ho heads are they the same or close to mine?
ORIGINAL: AdderMk2
quite the opposite... TW heads are the only ones that DONT have PTV clearance issues on an 86
ORIGINAL: mojopony
You might have P/V clearance issues on an '86.
to be honest 86gt....just save your pennies and do an H/C/I all at once you could go twisted wedge and not have PTV issues but better since you have so many miles on your motor just pull it in the winter and do a scuff and dip meaning pull it apart and put some worth while pistons in it which don't limit your head choice and or cam choice and then you'll have a ride you will enjoy of course if money is an issue you can flycut your pistons and that'll save some money if your motor runs well with all the miles without burning oil then the what I call scuff and dip/paint it blue call it new will work....meaning , rings bearings cut the ridge off at top of cylinder bore with a ridge reamer and hone it...and gaskets and of course to top it off a fresh can of ford blue engine paint!!!!
Luke9222
10-22-2015 11:55 PM
