Water Pump
Old Oct 4, 2007 | 10:08 PM
HotpodStang's Avatar
HotpodStang
Default Water Pump
I'm changeing out my water pump this weekend and I was wandering if I could get some pointer due to the fact I have never done this. I searched it and only came accross stuff on the 93 and below is it basiclly the same? Thank.. BTW I have a 95 Sorry just realized wrong section too
Old Oct 4, 2007 | 10:32 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
Default RE: Water Pump
remove all your assesories out of the way. remove the water pump. scrape away the old gasket material. put down some gasket sealer down on both sides. install the pump then reverse the process. hour at the most depending i guess.
Old Oct 4, 2007 | 10:34 PM
HotpodStang
Alright sounds simple enough thanks
Old Oct 5, 2007 | 10:07 AM
AdderMk2's Avatar
AdderMk2
Banned
you dont even have to remove any of your accessories... everything is bolted to your heads. Just unbolt your WP pulley, drail all your coolant, then remove the WP
Old Oct 5, 2007 | 11:04 AM
FivePointOhh
in limbo
ORIGINAL: AdderMk2
your right. i was thinking removing it all since i just did that to mine recently now that the motor is all tore apart. but everything is nice and clean now that i've taken it off, glad i did clean everything, it was lookin like poop.
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
