Power Window Issues
Old Nov 23, 2007 | 10:22 AM
LilBluPony's Avatar
LilBluPony
Default Power Window Issues
I have 2 power window issues that I need your help on please......
#1 - the pass side window goes down fine. when coming up, it hesitates have way (like really slows down), and then completes normally.
#2 - the drivers side window goes down fine, when coming up, I think it comes ajar, and I have to put my hand on the glass so it continues all the way up without stopping.
Ideas? So far I removed the pass side panel and looked inside. Looks ok to me but what do I know. Could it be something as simple as need greasing? And if so, what kind of grease? What about new pads? Hmmm....I do have new power window motor? Could that be it? I haven't touched the drivers door yet. Wanted to get one at a time done. Ideas? I know someone knows the answer...............
Old Nov 23, 2007 | 05:08 PM
The Whistler's Avatar
The Whistler
Default RE: Power Window Issues
Replace the nylon bushings in the motor. They pretty much turn to gel after the years. It take about 30min per door.
Old Nov 23, 2007 | 05:13 PM
LilBluPony's Avatar
LilBluPony
Ok, I'm stupid so what is a nylon bushing and would it be easier to just replace the motors since I do have them?
Old Nov 24, 2007 | 11:00 PM
stang8689's Avatar
stang8689
motors too, mine are slow
Old Nov 26, 2007 | 11:28 PM
natbel08's Avatar
natbel08
the same thing happend to me. 4 times (2 to each. rebuilding the motor only prolonged the life of it by a few months)
i would just find some window motors with a lifetime warranty on them and be done with it
Old Nov 27, 2007 | 05:03 AM
65coupe88hatch's Avatar
65coupe88hatch
My windows act sluggish coming up on my 88, my teacher at school told me to check all the grounds for the wiring of the motors, so we pulled the panels and sure enough that fixed the problem, rust was causing resistance and causing it to take more juice to go up and it was fighting itself...just a sugestion. but I should of greased it while the panels were off[:@]
Old Nov 27, 2007 | 05:01 PM
1GT2NV's Avatar
1GT2NV
i guess its a common thing cause i just went out to move my car and my passenger side window was stuck ....so im now stuck with an open window on my car atleast im luckey enough to have a garage so i dont get robbed im gonna mess with it later ill tell you what works
Old Nov 27, 2007 | 05:13 PM
LilBluPony's Avatar
LilBluPony
Dang, that sucks. Yeah, let me know. A friend of mine offered to replace my bushings and motors. I have some newer motors but not brand new ones.....good luck with yours!
Old Nov 27, 2007 | 06:59 PM
65coupe88hatch
ORIGINAL: 1GT2NV
mine did that once before, push the button rapidly mine worked after that. i havent used it since tho scared itll stop on me [:@]
Nick Oliver
Oct 17, 2018 04:22 AM
mustangchef
Sep 4, 2015 08:08 PM
whatsup62
Sep 3, 2015 01:38 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
