HUGE PROBLEMS
Old Nov 29, 2007 | 02:53 PM
blk40th's Avatar
blk40th
Default RE: HUGE PROBLEMS
so is the belt still around the p/s pump pulley? if so you should take it off as the pump will burn up. did you try the plug thing. also u might want to try n tap the starter while someones tries to crank it.
Old Nov 29, 2007 | 02:58 PM
21xmustang's Avatar
21xmustang
yeah its still arround the pump, like i said its just dummied there cus i couldnt find a short enough belt not to put it there, and i dont GAF about the pump it can burn up cu i dont want power steering, power steering is for pussies. but no i didnt try the plug thing yet but im goin out there to work on it tonight, and ill try it
Old Nov 29, 2007 | 03:14 PM
blk40th's Avatar
blk40th
ok well not that you said that. how long did you run the car with no fluid? or is there fluid? try taking the belt completely off and starting it. do that before pulling plugs.
Old Nov 29, 2007 | 03:22 PM
21xmustang's Avatar
21xmustang
no there is no fluid in it, i just pulled the hose off that goes from the pump to the rack, drained it of fluid, and bolted her up, and im realy hoping that this is my problem.
Old Nov 29, 2007 | 03:51 PM
blk40th's Avatar
blk40th
omg dude that thing much scream like a sob. lol i think at this point ur first step is to take that belt off and try with the key. if nothing pull some plugs and try that. i doubt the plug thing will really help but definitly try it.
Old Nov 29, 2007 | 03:56 PM
21xmustang's Avatar
21xmustang
ill most definately be trying some of these things tonight, hopefully she will be running by the time i leave, ill keep you guys posted, oh yeah i got some pics of the build up on the car, and before/afters ill try to get some up on here.
Old Nov 29, 2007 | 07:24 PM
ahittz24's Avatar
ahittz24
ORIGINAL: 21xmustang
Wow... umm thats all I can really say about that is.... wow... Would you ever run your engine without oil???
Old Nov 29, 2007 | 09:26 PM
capri debris's Avatar
capri debris
You unhooked the hose to the P/S pump and drained the fluid, then drove the car with the belt turning the pump....... and you didn't foresee a problem? I can't believe some of the things you guys are doing to your cars and then seem suprised when you have problems.
Wow........ just WOW.
Old Nov 30, 2007 | 07:44 PM
21xmustang's Avatar
21xmustang
yeah i know that was not smart, but i did get it fixed, i just bypassed the pump, but now i have more problems, i got it dialed in took it down the road and all it does is spin the tires, this concerns me cause i have 2756015 drag radials on it
Old Nov 30, 2007 | 09:54 PM
capri debris
I'm glad you got it fixed... as for the other "problem" of having too much power that all you do is spin the tires... well, that's a good problem. LOL.
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
