Cam Question
Old Dec 28, 2007 | 04:12 AM
BlackFox's Avatar
BlackFox
Default Cam Question
Curious as to what suggesions i could get from you guys. Going to be running AFR 165's and TFS Track Heat intakes. I've heard the stock cam is still good for me but i wanted to get as much hp as i can and sense im gonna have the motor apart why not change the cam out to match right? I was told the TFS Stage 1 was good but i cant figure out which one that is actually. Thanks guys!
Old Dec 28, 2007 | 07:18 AM
92GreyGT's Avatar
92GreyGT
Default RE: Cam Question
If it's a 302 then the stage 1 is good but if you are looking to sound good and make some more power check stage 2.Also call Comp, Lunati, Crane, etc and see what they have to say. Iam using a Comp XE274 cam and it works well and sounds good also.
Stage 1:
http://store.summitracing.com/partde...p;autoview=sku
Stage 2:
Old Dec 28, 2007 | 09:57 AM
BlackFox's Avatar
BlackFox
And both of these will work on the stock rollers? Or should i change to 1.7's? Also whats the main difference between the two?
Old Dec 28, 2007 | 11:14 PM
BlackFox's Avatar
BlackFox
bump
Old Dec 28, 2007 | 11:28 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: BlackFox
Yep stock rollers are fine..heck I ws using stock rollers for a xe282 hr cam =565/574 lift..but I'm upgrading them here soon for my 347 and stick with 1.6's you'll be fine
Old Dec 28, 2007 | 11:30 PM
Mustangkiler's Avatar
Mustangkiler
Always a good idea to switch to roller rockers, and your afr heads might be stud mount so you might have too anyways, but with a tf stage 1 cam you will need to use 1.6 ratio rockers if your using stock pistons, and you will have to measure and get new hardened pushrods.
Old Dec 29, 2007 | 09:32 AM
BlackFox's Avatar
BlackFox
tfs stage 1 or 2 cam better than an e cam?
Old Dec 30, 2007 | 12:22 AM
SICNINETYCOUPE's Avatar
SICNINETYCOUPE
tfs cams are ok. alphabet cams are junk. if you want off the shelf you cant beat Anderson Ford Motorsport cams. im on my 3rd grind and they are just get better every time i get a new one. i ran the n-41, b-31 and am currently running the b-41 hi-rev, its sic. i picked up 17rwhp from the b-31 just on motor, almost 30rwhp on the sauce. driveability is really good considering the size and the power band is awesome motor screams around 3500 and pulls clear straight to 6500.
Old Dec 30, 2007 | 08:28 AM
BlackFox's Avatar
BlackFox
thanks man ill look into those
Luke9222
Oct 22, 2015 11:55 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
