Need suggestions on head cam combo for 94 5.0!!!
Okay, Guys this is a list of what i have on the car and I need to know what cam, heads and Roller rockers will make the most power.
-professional products Upper and lower intake ( knock off of Eldebrock Performer)
BBk shorty headers
Under Drive pullys
X pipe
Flowmaster stage 1 cat back
373 gear
Short Throw shifter
65 mm tb
Cold Air intake
Stock Mass air
Stock Injectors
175 shot of gas from Cold fusion
Stock Bottom End!!!
... as it sits with stock head and cam I am in the low 12's. Please let me know the easiest and cheapest way to do my top end!!
BBk shorty headers
Under Drive pullys
X pipe
373 gear
Short Throw shifter
65 mm tb
Cold Air intake
Stock Mass air
Stock Injectors
Stock Bottom End!!!
RE: Need suggestions on head cam combo for 94 5.0!!!
if you drive it alot get a cam that wont mess up the idle its a pain to fight the surging hanging idle
i have the tfs stage 1 I like the cam but its screws with the idle.(if i had it to do over I would get the steeda #19)
how do you keep it from spinning when you hit the nitrous?
Im hitting a 125 dry and blowing the tires up
I got a few good runs rolling out and then launching in the low 12's with 315 mt drag radials on it
im not gonna put trickflow down ..they have great products..n with a little port work are amazing..but my buddy put the whole tf topend kit and for all the money he spent, i think it coulda been better..so personally id do some research n piece together ur own kit...hes runnin untuned right now..n the tfs1 cam sounds really nice and i really dont think he has that much problem with it..its in a 95 ..right when it got back together there were some issues with it dieing when changing gears(auto) but i think he got it worked out
ORIGINAL: kevinas1214
BBk shorty headers
Under Drive pullys
X pipe
373 gear
Short Throw shifter
65 mm tb
Cold Air intake
Stock Mass air
Stock Injectors
Stock Bottom End!!!
BBk shorty headers
Under Drive pullys
X pipe
373 gear
Short Throw shifter
65 mm tb
Cold Air intake
Stock Mass air
Stock Injectors
Stock Bottom End!!!
BBk shorty headers
Under Drive pullys
X pipe
373 gear
Short Throw shifter
65 mm tb
Cold Air intake
Stock Mass air
Stock Injectors
Stock Bottom End!!!
BBk shorty headers
Under Drive pullys
X pipe
373 gear
Short Throw shifter
65 mm tb
Cold Air intake
Stock Mass air
Stock Injectors
Stock Bottom End!!!
http://www.veryuseful.com/mustang/te...InnerWorkings/
uberstang1
09-20-2015 06:42 PM
