Dyno Numbers
Yes that would be maxing the blower and 680hp, which he is clearly not doing and 390hp. Running the SC trim at 10lbs is far from it's capabilites. A T-trim or Novi 2000 would be better if he had a stronger block to put it on. Stock, stroked, heads/cam 302 block will quickly see it's limit with a S-trim. Hell, many people have gone 9 sec times with that blower. The supercharger is not making the low numbers.
[/quote]
Never said the s/c is the reason for the low numbers. i said its a cork for that kind of power plant. Strong block or not it has nothing to do with it, the novi 2000 or t-trimwould make more power with the same or less boost period. If your worried about breaking parts a bigger blower will make more power and do it with less boost = less stress on the shortblock.
I knew a more expensive/larger blower would make more powerwith the same orless boost, and that I've still got potential for more boost with my current blower. I'll probably go to a smaller pulley soon and see what that edlivers, but am not going to get too crazy, since I absolutely do not want to break parts. It's been a long time in the making and I just want to enjoy the car for a little while.
ORIGINAL: SICNINETYCOUPE
ORIGINAL: OneFastEclipse
Something being a cork means that it is holding it back. Again, that blower is not holding back his setup. Yeah, a bigger blower would make more power at the same boost, but it would do the same on any engine, not just a built 347. Actually, the difference between a T-trim and S-trim at the same psi has been shown to be minimal. The main benefit of a T-trim is the fact that it can be spun faster and has a higher boost capability. He is looking to run lower boost levels so that really don't matter on his part. Basically, for the power he is looking to make, a T-trim or equivilant would be a bit over kill. The S-trim is just fine until he is ready to push some serious power.
ORIGINAL: bouchermb
The point is that using a bigger blower is morecrucial on a larger displacement engine for max efficientcy and power production so if that was what he was looking for (wich he is not) then YES that blower is holding him back.
and he is not running an S-trim he is running an SC trim totally different.
Im not sure where yougetyour infocause there's a power difference even just between the V-1 S-trim and the V-2 S-trim let alone the T-trim and S-trim. the T-trim and S-trim have similar impelers and volutes the housings are different sizes = more flow. more flow= more power. try filling a baloon with a straw and onewith 3/8" tubing see wich fills up faster same diff.
I'm not saying any of your info is incorrect, I just personally don't see the SC-Trim holding him back AT THIS POINT.
ORIGINAL: OnyxCobra
what?! O_O I WISH
Stock 94/95 Cobras put down roughly 220whp. Stock Terminators (03/04 Cobras) Do something in the area of 370whp.
he said he did...
ORIGINAL: MarkNieb
What's a terminator? I thought all cobra's 94 up used the same engine, just changed body styles...
ORIGINAL: nacanitihs
didnt adder get 270rwhp out of his 95 cobra w/ a tune?
Galactic
Apr 29, 2019 02:56 PM
Sep 23, 2015 01:28 PM
