question on v8 conversion
Old Jan 24, 2008 | 03:44 PM
saleen coupe's Avatar
saleen coupe
Default question on v8 conversion
I know i need the computer and wiring harness and the 8.8 rearend, but i was wondering if i needed to replace the brakes and the front suspension or what i'm trying to decide if i want to do this or just wait for a cheap v8 car.
Old Jan 24, 2008 | 07:44 PM
nitrousd85's Avatar
nitrousd85
Default RE: question on v8 conversion
spindles and such you want it to stop dont you
find a v8 fox in a junk yard and youve got it
Old Jan 24, 2008 | 08:01 PM
stanglx2002's Avatar
stanglx2002
For a 5.0 Conversion use have to replace these parts:
Computer wiring harness (Dash harness doesnt need replaced)
Brake booster
Master Cylinder
Small brake lines coming from master cylinder
calipers
spindles
rubber brake lines
rearend
fuel lines
tach
I thinks thats about it
Old Jan 24, 2008 | 09:08 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
not necessary whatsoever to upgrade the brakes ...why?? the 4cyl models have 10 inch brakes ..infact the same size as the 5.0's up to 86 had until switching to the 11 inch in 87...my 92 4 cyl conversion to 5.0 still harnesses the 4 cyl 10 inch rotor set up and has seen many mid 13 sec passes just fine and stops great
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
soliddrummer
Mar 10, 2006 02:21 AM
gabeh1018
Oct 10, 2005 10:34 AM
karazuba
Jan 22, 2005 04:49 PM
