QUESTION ON BALANCING ENGINE
Old Mar 4, 2008 | 03:33 PM
abreimeris's Avatar
abreimeris
Default QUESTION ON BALANCING ENGINE
Have a 5.0 that was balanced by drilling holes into the harmonic balancer, and the flywheel. What happens if I need to get a new flywheel? Does the entire engine have to be taken apart again for balancing?
Old Mar 4, 2008 | 03:39 PM
67mustang302's Avatar
67mustang302
Default RE: QUESTION ON BALANCING ENGINE
They balanced the engine by drilling the balancer and flywheel? Or they balanced the flywheel and balancer?
Old Mar 4, 2008 | 04:00 PM
woodsy's Avatar
woodsy
You want to avoid taking material from the flywheel and balancer at all costs, its the worse thing you can do. If you need to replace either of those items you need to find a shop that can replicate the part you are replacing. These are wear items and you always want to take the material out of the crank when balancing.
Old Mar 4, 2008 | 04:04 PM
PJC Racing's Avatar
PJC Racing
ORIGINAL: woodsy
Jim?
woodsy's Avatar
woodsy
shhhhh
Old Mar 4, 2008 | 05:23 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: woodsy
ha ha ha!! sounds like the same thing I was talking to you that happened to my old rotating assembly.. it all make sense now!!!
Old Mar 4, 2008 | 07:19 PM
abreimeris's Avatar
abreimeris
Damage is done. The entire rotating assembly was balancedby the Flywheel and the Harmonic. Going to call that place and bitch! They also took some weight off from the crank as well, whick is ok. Exactly why I am asking,flywheels do wear out.
Old Mar 4, 2008 | 07:27 PM
mjr46's Avatar
mjr46
^^^^don't feel bad.. .the same thing happened to me not to long ago and all the damn machine shop did was point to the sign on the wall that says no warranty on performance engine......IMO...a cheap cop out for the allowance of shyty work!! which is why I had a reputable builder do my current engine this time
Old Mar 4, 2008 | 07:39 PM
abreimeris's Avatar
abreimeris
Yea, I am new to the area, and wasn't sure. I used to live 5 miles from DSS Racing. I know Tom the owner over there.Would be cool to still live there.
mdj89
Aug 31, 2015 07:27 AM
1987gt40ttopt
Aug 28, 2015 10:49 PM
Urambo Tauro
Aug 27, 2015 10:53 AM
classic69FB
Aug 12, 2015 11:58 PM
HIS S-197
Aug 10, 2015 05:47 PM
