Ohio mustangs
Ohio mustangs
Hello i live in ohio, does any body know of a good performance shop close to akron area. I need to get some work done and in looking for a good exchaust shop to iinstall o/r h pipe with flow 40 series any body can help me. 1 more question if i put trick flow heads on my car what else would i have to change i plan on putting t/f heads and intake how much hp and im goin to gain its got the 5.0 motor.
RE: Ohio mustangs
I'm in Canton, not too far from you if your in Akron. Two big places around here are www.akronhorsepower.com and www.bigshotdyno.com. A exhaust is simple enough to do yourself unless you're planning to have stuff welded up. Trickflow heads alone on your car, you'll prob see 30-40 HP gain. Compliment it with a nice intake manifold and a cam, you'll see a lot more.
RE: Ohio mustangs
So i lived really close to both you and never could find any other stangers around....wtf, now i move and you guys come outa nowehre, haha. Summit will have everything you need ofcourse....i'm not too sure of any shops that do performance work around there tho. Hows the weather up there theses days ? I sure am glad i missed out on winter, Texas weather suites me alot better.
RE: Ohio mustangs
ORIGINAL: RED95
As stated by onefasteclipse both shops he has listed are very good shops in the local area.
If you plan on going with the Trick Flow Heads and Intake, take a look at the top end kits that we have available. The 360HP/350 ft lb of torque kit will get you about 280-290 RWHP with a good tune. To go along with this kit you will need the follow to go with it.
24 lb injectors
70mm TB
75mm Mass air meter
190 lph fuel pump.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
01-06-2016 07:03 PM
