347 stroker kit
Old Jul 8, 2008 | 12:35 PM
kjpenka1's Avatar
kjpenka1
Default 347 stroker kit
Im sorry if this is tech specific but i couldn't find the tech specific thread, it could only find the general 5.0 thread, but anyway i was wondering if i purchase the 347 stroker kit for my 5.0 what are some of the other things that i would have to modify on the car? I was thinking heads because changing the stroke must change the compression to an extreme extent. Also are there other things that i don't HAVE to modify but probably should? thanks for any input.
Old Jul 8, 2008 | 01:01 PM
Jrichber95GTS's Avatar
Jrichber95GTS
Default RE: 347 stroker kit
well if you put stock heads on a 347 your wasting the time and money that was put into that 347 should also go better intake injectors MAF TB fuel pump etc. but really you dont have to themotor would run with same stuff as it is stock but wouldnt be as much fun[sm=yeahsmile.gif]
Old Jul 8, 2008 | 04:37 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
heads cam intake , tb, cai, exhaust, gears, proper fuel system, mass air calibrated for larger injectors ,,ect ect............
Old Jul 8, 2008 | 07:14 PM
stang347gt's Avatar
stang347gt
^ what they said
i say go with afr 205 cc heads
trick flow intake
ford x-303 cam
30 lb injectors
good combo
Old Jul 8, 2008 | 08:28 PM
mjr46's Avatar
mjr46
ORIGINAL: stang347gt
trick flow intake
ford x-303 cam
30 lb injectors
good combo
eliminate the X cam and pick something better..like a dual pattern such as a comp xe series cam or xfi stroker cam or custom cam for combo
Old Jul 8, 2008 | 11:48 PM
jtmustang's Avatar
jtmustang
^^^ agreed the x cam is alright but their are better cams out there especially for a stroker
Old Jul 9, 2008 | 05:12 PM
stang347gt's Avatar
stang347gt
really?
what r some good cams out there?
b/c trickflow stage 2 cam is the same as my x cam
but if he wants it to be efi also..ford has a z-303 cam also..
Old Jul 9, 2008 | 06:52 PM
andywear87's Avatar
andywear87
really?
um no!
trick flow stage 2.
Camshaft, Track Max, Hydraulic Roller Tappet, Advertised Duration 286/ 294,Lift .542/ .563,Ford,Small Block,Ea...
Ford Motorsport / SVO
[align=center]M-6250-X303[/align]
[align=center]286°[/align]
[align=center]224°[/align]
[align=center]0.542'[/align]
[align=center]107° / 117°[/align]
[align=center]3,500 / 6,500[/align]
but i would say a custom grind cam shaft is the way to go cause for what i spent on my cam i could have almost bought a custom cam from jay allen but the xe cams are good and the trick flow cams are decent
Old Jul 9, 2008 | 09:05 PM
mjr46's Avatar
mjr46
really?
letter cams were designed for the 302 in mind not 347...and stage two is not the same as x!!!! stage 2 is a dual pattern cam= better
Old Jul 9, 2008 | 09:09 PM
code3GT's Avatar
code3GT
Mustang Nazi
You can get by with a little smaller heads than AFR205's on a 347. I ran Trick Flow Track Heats on my 347.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
