e-cam
i think the B feels better performance wise...more repsonsive except there is a bit of lag between idle and 2500 RPMS. but the E cam just sounds way better at idle but i just dont feel much performance out of it over stock.
you'll have to take the heads off to replace your springs unless you fill your cylinder with twine or compress the cylinder with air so your valves dont fall into the cylinder.
but no springs wont help ET's just ensure proper seating pressure and overall operation of your valvetrain. however with some RR's you will gain a bit of HP's.
http://store.summitracing.com/partde...rt=TFS-2500100
if you go onto the summit website and look up the product, it'll have related products and it will match the spring to the cam.
