dyno!!!!!!!
Old Dec 21, 2008 | 09:08 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
What mods do you have that you think you require a tune. Sounds like starting w/ the basics is in order. Cleaning the IAC and the t/b. Maybe you have a vacuum leak.
Old Dec 21, 2008 | 09:19 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
check your MAF is plugged in, clean your MAF with MAF cleaner, check/ clean your IAC and make sure its plugged in. check fro vac leaks with either a smoke machine or carb cleaner. check your base timing, set TPS between .6 to 1.01 volts, set base idle. and run koeo/koer and normal operating temp.
if you still have problems, let us know
Old Dec 21, 2008 | 09:23 PM
83gtragtop's Avatar
83gtragtop
Originally Posted by 86 5.0L
:O thats cheap, I havent really looked for dyno shops since I know they are pricey and im in college
Not to high jack but where are you going to college in SD? I'm starting grad school in Jan at SDSU.
Old Dec 21, 2008 | 09:42 PM
86 5.0L's Avatar
86 5.0L
right now I am going to a community college(Imperial Valley College) for my lower division and general ed classes, hoping to transfer to SDSU in probably a year
Old Dec 21, 2008 | 10:45 PM
crusin92red5.0's Avatar
crusin92red5.0
My car is having the same issue after i did my HCI. i recently found out that they make a part that goes between the IAC and the throttle body that lets you adjust/help the idle. Ford sells it. i haven't bought the part yet, but i plan on it.
Old Dec 21, 2008 | 10:47 PM
grnstang's Avatar
grnstang
you definnately need a tune. i tuned my full bolt on stock motor and it needed leaned out and made a substantial difference
Old Dec 22, 2008 | 09:07 AM
FivePointOhh
in limbo
really...so what exactly did this "tuner" do? modify your computers functions or did they adjust your car correctly to make it run right??
Old Dec 22, 2008 | 12:49 PM
86 5.0L's Avatar
86 5.0L
make sure the A/F ratio is within range throughout the rpm range
Old Dec 22, 2008 | 01:17 PM
sdstang306's Avatar
sdstang306
dang all these 5.0l
gonna be moving on to my turf
i live on just the other side of the freeway from sdsu~
Old Dec 22, 2008 | 01:29 PM
FivePointOhh
in limbo
nothin like spendin a couple hundred dollars to look at a graph.
