suspension?
Hey PRO, one more thing. I just went to my local mustang shop and asked them about the 4cyl springs up front. The guy said he's definitely seen people do it, but he has heard that they are very bouncy, what do you think about them?
Well if you just want looks and straightl ine performence do the 4 cyl springs if you want to have nice handling and lowered all around then get some eibach springs some goos struts and shocks and some castercamber plates.
Stock c/c plates also and so far there have been no issues w/ tire wear. If it starts, I'll put a set on though. Not a big deal to install.
I had them on my 92 for a short while after coverting it to a 5.0 , AND i WISH i HAD OF LEFT THEM on, the stance was cool and ride good
I agree the ride with 4 cylinder springs does not have to be bouncy at all. If your struts are shot then it really does not matter which springs you use your ride wont be super.
In fact the constant rate of the 4 banger spring has *can* improve your handling, it is possible & older fox years the same springs were used in 4 bangers & v8 as far as I can tell... they had the exact spring rate for several of the model years and close rates for other years... I have asked on several forums if the uncompressed spring length in those years was the same and nobody knows so It seems that the same exact spring v8 & I4 so no reason to not use 4 banger spring...
The 4 banger spring rate is 370 for 1979 to 1992 and 400 for 1993
v8 fox mustangs used constant rate springs 1979 to 1984
1993 cobra used the same front spring as 1993 4 banger: 400 ft/lb
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
