front swaybar question
Old Dec 30, 2008 | 03:09 PM
saleenpride1986's Avatar
saleenpride1986
Default front swaybar question
I'm getting one of the maximum motorsports complete suspension packages. I noticed on my quote i got from them it says "check from swaybar diameter." Has anyone here purchased one of their kits and do you know what exactly they mean by that? How can I check that also...
Old Dec 30, 2008 | 03:52 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
stick an open end wrench over the bar until you get one that fits snug and there you have the thickness
Old Dec 30, 2008 | 04:00 PM
saleenpride1986
haha thanks! simple as that!
Old Dec 30, 2008 | 04:10 PM
Hamutoff's Avatar
Hamutoff
Using a wrench to determine the sway bar installed might be difficult because they vary in small increments sometimes in 1 mm..............
If you have a stock unit from 1990 you might be able to tell if its one of three with the wrench. It could be 23.9mm, 28.6mm, 33.0mm...
I had a hard time with my mic determining the diff in swaybars from my 87ssp and 87 turbocoupe, I later found info to make me believe they are most likely 21.1 and 20.1 respectively (they have a slightly different design too). I measured several different places on the sway bar after grinding the area free of paint and contaminants and averaged the #'s to find what they likely were on the books: tbird was most likely the 87 Base (non V8) sway bar and the ssp was likely the 87 Handling (GT) there was only 4 thousanths difference, not visible with 'wrench mic' id bet - just a heads up & share my experiance
04stangman
Sep 17, 2015 01:45 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
