an oil question
you should of seen the chevy malibu I did an intake gasket on last week....talk about sludge in the motor, the filter was plugged up and when i LET THE DRAIN PLUG go, it looked like diareaha coming out and there was so much sludge you couldn't even see the tops of the lifters, funny thing was the kid said he was doing frequent oil changes, I asked him where and he said WAL-MART ....LOL GOTTA LOVE THE 14.95 LOF they sell
haha i did an oil change on a 3.0 ohv Taurus and it was so sludged up that in 10k miles the oil filter had maybe a couple drops of oil in it. it was still just as light as a brand new filter. the sludge blocked off the filter passageway and was just going through the filter bypass
wow...
so basicly the whole "synthetic oil will cause your car to leak" should be "If synthetic oil causes your car to leak, then you needed to fix your car." lol.
I knew synthetic made better hp, I've read to many articles on that one to think otherwise.
As for the marketing gimmick, your telling me, the freaking conventional high mileage stuff costs more than the synthetic stuff...
Synthetic oil it is.
one of the main reasons I run synthetic oil is due to the detergent and additive packages you can go longer between oil changes with out the ill effects of them breaking down and sludging up the motor, I have run amsoil in my wifes D\D since day 1 and it now has 180k on it , yeah so the cost of my oil change is 2 to 1 using synthetic vs conventional but I also go 7500 miles between changes where as if you followed the regimine of 3000 mile oil changes with conventional then the cost is no different cause in the 1 oil change of synthetic you'd have the cost of 2 conventional changes.......so in the end it all balances out and as far as I can tell the upper half of my wifes camary is spotless!!
i went almost 200k miles with conventional in my stang lol. i did how ever take the valve covers off shortly before it died to take a look at stuff and it looked like it was starting to sludge up and i was doing oil changes every 2000 miles
some cars just suck that way. like toyota they had a tsb out for replacing engines that had failed due to sludging while maintaining the normal oil change intervals. some areas of the engines were getting so hot they would kill the oil and make it sludge up and the engine would blow.
yes I said twenty thousand the oil I buy is good for 25000 but 20,000 is easier to keep track of.
check out the delivery guy who went 1 million miles on his van motor and trans, changing the oil every 25k and trans fluid every 150k
www.shadyninja.com/host/million-mile-van.pdf
